Easy3D
14
Please,
Don’t tell me you think this is a good printing…
Compare it to this one:
Jory
16
+1 - The Zortrax has better print quality than any desktop printer I found under $5k that was willing to send samples. Only downside I see to them is build size and proprietary material options (unless you want to void the warranty).
I would never purchase a printer that has proprietary filament only usage. To me that defeats the purpose of trying to be creative and experience all the new filaments that come out. I would by a kit and build my own reprap printer before buying one that limits me. Just my opinion.
Jory
18
I agree to a point, hence the reason I got us a PolyPrinter instead. But…the Zortrax did still have the best results on my test part, even with a single extruder. It looked better than our Dimension machine, which is pretty good for accuracy due to the soluble support it uses.
Thank you very much everybody for taking the time to answer. I sent a quotation request to Zmorph a couple of days ago and got no answer so far, this doesn’t give me a good spine.
Hi Mousetrap,
Thanks for your answer. Unfortunately there is no Fablab in my country so I can try this printer, from what I see here in 3dhubs, nobody owns one. It interest me mainly because of the “alternative” materials as well as milling and laser. Do you think it’s worth the money purchasing the full set considering it’s limitations on these additional tools?
thanks! I just liked your fb page
Hihttps://www.3dhubs.com/orlando/hubs/scott Octopuslab, I own one on the ZMorph printers and I posted a picture of the Marvin that I originally printed. Also you can check my 3dhubs page to see some of the other things I have printer for customers and the positive review I have received. I have no issues with my printer, maybe all the negative feedback is due to not learning the printer and what setting work better than others. Visit my page at https://www.3dhubs.com/orlando/hubs/scott
Hi @Scott3d
I guess you are right; I have checked your and other prints and they look good to me.
Have you tried the added tools (laser and milling)?
They are in use in Fablab Essex , you can buyin the UK from MouseTrap Innovation Ltd , try them outem out on 3D hubs MakerDen
3D hubs - Makerden Basildon UK offers prints on Zmorphs
Hey @shashipalsadana, those are really great results! Would you like to share some of your printing experience in our ZMorph community: what type of materials have you tried, print settings that worked best aso? Let me know how this sounds. Cheers
sorry for the late responce you can see the marvin from zmorph in the pictures of our hub, also in the question of the other heads we have use them all of them
laser is 4w so dont expect to cut wood ( need a lot of passes for that) , engraving is easy
check in our facebook page for videos of the laser and dremmel head
can post here your settings ? what kind of material ?
A tip that actually no one tell you , fillament quality is always crucial in fdm printers , actually we minimize almost to 0 the problems in printing by use only hi quality fillaments i suggest you Colourfabb ,Formfutura , proto-pasta ( we have use them and the 3 of them with great results )
Hi! We are dealers of Zmorph in Ukraine. We can answer the questions that we have understood. We have all toolhead of Zmorph.
www.3Dprint.com.ua
Yes , we actually had use in our office allmost all the heads, Zmorph has 3 big possitives open source,rigid contruction ,many different toolheads.The voxelizer is great software and works well ( in 3d printing we use S3D cause we have seen differences in the quality of the print).Is extremely relliable machine about the laser moduleis 2W so is mostly for engrave not for cutting, also is better as practise to save the gcode to SD not print live and the last that until now dont have a wifi connectivity (that you can solve it easy)
i think it is a good solid print, however the micron level (smoothness) is not so smooth looking.
What isthe minimum and maximum micron size for the Zmorph S2.0 NEW
