Japper
Hi-
I have a Maker Select 3d printer which has been working great for some time but lately the prints are coming out delaminated on most every layer.
I am using 1.75mm PLA filament with the following Cura Settings:
Layer Height = 0.3
Shell thickness = 0.8
Enable retraction = checked
Bottom/Top Fill thickness = 0.9
Fill Density = 40%
Print Speed (mm/s) = 40
Printing temperature © = 195
Bed Temperature © = 45
Support Type = None
Platform adhesion type = brim
Flow (%) = 100.0
Any suggestions of what I might adjust to fix this delamination problem?
For a .3 layer I might jump the extruder temp up and see how it goes or go back to a .2 layer and see how that is.
Japper
Thanks for the suggestion wirlybird. I will try that later today
