soul4u
https://www.file-upload.net/download-12574761/WhatsAppVideo2017-06-27at12.50.00.mp4.html
For whatever reason the ultimaker II Extended stops in the middle of a print. Does anybody have an idea? After the last dozend of problems everything worked fine for the last days…this is new and I dont know where to look at! Thanks for any help!
Xeno
Please edit your link, it doesn’t work, or use another method like Youtube
You need to tell more it could be many things.
MHPUNE
go in tune check nozzle temperature and all other settings 1st … also clean nozzle again properly. send all settings details so i can help you…
Also the official Ultimaker forum might be a better place to ask for help:
Are you printing over USB or SD card?
soul4u
8
…believe it or not …I did read somewhere that cleaning the sd slot with compressed air could help…so the stops could been caused by problems with reading the SD card…I did simply blow a few times into the slot - avoid spitting - …and the dammed printer is working without problems since yesterday now… lets see, what problem occurs next…
