You are the one being rude. His advice is correct. To change the height of the nozzle in relation to the other nozzle you have to loosen the barrel where it attaches to the cooling bar and slide the entire hot end assembly up or down. Loosening or tightening the nozzle itself is absolutely the wrong thing to do and will only lead to problems with extrusion.
Hello I am not familiar with the FlashForge but I would like to offer the following:
1. I am pretty sure the nozzles need to be at the same height…I would call support to work with someone on adjustments.
2. If you are getting a melted look it might be worthwhile to look at your extrusion rate and temperature. In my experience when I have a melted look it is due to over-extrusion and I correct it by adjusting the multiplier in the slicing software.
3. The first layer of a print is very critical to the success of a complete print. Particularly with PLA, as the plastic cools it also shrinks. So stickiness is important to keep corners and the entire first layer secured to the print bed. First make sure your nozzle height at layer 0 (zero) can pass the paper test. There is not much tolerance allowed for variance in layer 0 nozzle height. For my printer, any change in room temperature (+/-10 degrees) requires a nozzle height adjustment. Also if I jar or bump my printer/bed I will need to a paper test and adjust. Sometimes you can also increase the first layer height for the filament and also add a brim in the slicing software. If I have a long print with corner (~2-3 hours) I will always add a brim of 3mm. Hope this helps!!
JADL26
23
I own a CTC 3d printer (Makerbot Replicator clone like the FFCP) and when i got it i experienced the same problems that you seem to be experiencing.
1. For some reason, the manufacturers of replicator clones think that the buyer is only going to use 1 nozzle and ship their printers with the primary nozzle lower to reduce the chance of the other one catching on your print. To solve this, you have to remove the fans and heatsinks and undo the grub-screws holding the heatbreaks into the block that the fans screw into. now you can manually level the nozzles, re-tighten the grub screws and put everything back together
2. The melted look is a result of the temperature being too high. In Makerbot desktop, and therefore probably Flashprint, the default nozzle temp is 230 for PLA which is much too high. The temperature range for PLA is 180-220C but 195-205 is usually a good range to stick with. I do not print with ABS much because of the smell so cant recommend temperatures, but there are loads of guides that should give you an idea about the printing temperatures. With PLA, the FFCP’s lack of a print cooling fan will likely result in reduced detail along with other print artifacts. I recommend adding one to greatly improve print quality, Active Cooling Fan Duct v2 for Replicator 1 / Duplicator 4 / FlashForge / CTC by thruit00 - Thingiverse, however you do have to solder an extra MOSFET to the motherboard so you might want to wait until you are more experienced.
3.The print not sticking to the bed could be a result of many things but a few of the main causes i have come across are:
The bed temperature - When printing PLA on blue tape, you want an unheated bed because heating blue tape reduces adhesion between PLA and the tape. If that doesn’t work you may want to try other build surfaces such as a sheet of PEI instead of tape or a sheet of glass clamped to the bed which is what i have done.
The first layer height - If the bed is not properly leveled, using lower layer heights can result in the print not sticking to the bed. I have solved this by switching to a slicer that allows you to set a separate first layer height.
I have switched to using Slic3r as my slicer and since then my prints have been much better. I put this upgrade off for a while because i thought that messing arround with GPX (The post-processing tool that converts .gcode into the .x3g used by makerbotes and their clones) would be complicated. I found this video, Getting Started with the FlashForge Creator X - Slic3r on Mac OS X (3D Universe) - YouTube, and by following it and using a bit of common sense i had slic3r working within an hour. The great thing with slicers like slic3r is that they allow you to change a few things at the start, and adjust more and more as you become more experienced.
Sorry if this answer is a little long but I wanted to give you all of the information that i wish i had to sort out the issues with my printer when i got it just under a year ago.
Hope this helps
Jamie
I am also using Fleks3D. You do not need glue - not with PLA, not with ABS.
1.) Install clamps to press the Fleks3D down when heating the bed to 100 (ABS) oder about 50 (PLA). PLA also works unheated. Without clamps, the Fleks3D bed will come up on the left and the right side.
2.) Use sandpaper once in a while to make the surface sticky again. Use it in circular motion. The surface will become more opaque with this again while removing leavings from prints before.
too hot i have a ctc makerbot clone with a homemade enclosure and i print abs at 205c with a fan on for small things and 210c for big and the bad at 100c to 110c and abs juice is amazing and for pla lower the bed to 40c to 50c and use a fan blowing at the nozzles works for me but you may have to tweak it
